BFL13
Sep 03, 2013Explorer II
I lost track of whether that inverter is a 24 or 12v inverter. You have to pick what voltage you want to operate in. Seems like it must be a 24. You might find it is worth getting a 300w 12v MSW (under
$50) for TV/dvd etc. and switch to 12v battery bank.
Your usage and draws are like any RVer weekender type with a 12v system and no big draws like air conditioning, microwave, toaster, kettle, in that you can do those while on gen whenever you feel like it- no worries about campground rules for gen times.
For info, I have a 12v bank of batts about 490AH and a 100a charger that takes 2 3/4 hrs to do a "50-90." I would need more amps to get that to a two hour gen time limit.
But now how do you get from 90-100%? Nobody can run their gens that long, so now you need shore power or solar. Yes you could get back to 100% with a 100w 12v panel and a simple 8.5-10a PWM controller between visits to the cabin (assuming some sunshine happens then. If not,more gen time when you get there.
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
