SkiMore
Sep 04, 2013Explorer II
pianotuna wrote:
Hi skimore,
I would keep the batteries you have and see if they will meet your needs. Solar has a way of recovering batteries if there is a good temperature compensated charge controller.
Good to know. When I'm ready to do the install I'll ask the forum for controller recommendations.
pianotuna wrote:
I would start with a minimum of 60 watts per 1000 watts of storage. That would, in your case, be about 300 watts.
Since you are set up to do 24 volts I see NO advantages of down grading to 12 volts. LED's that will tolerate from 12 to 30 volts are readily available. One nice advantage is that you can use an inexpensive pwm controller (but one with temperature compensation please) to charge the battery bank.
I suspect with 232 amp-hours @ 24 volts (5568 watts) that you would have ample power for a weekend--and when you return for the next visit, the battery bank will be bursting full.
I'll go out on a limb and say you won't need to run the generator at all--and will be able to make that coffee electrically.
IMHO = in my humble opinion. (I almost always agree with Mex btw)
When you suggested LED lights I thought you meant 120V LED bulbs. I think I'd need to run new wiring to use 12-30V LED bulbs. Maybe I'm lucky and the lights were on a separate circuit from the outlets. Can I run 12V on regular house wires assuming I pop them out of that panel? This sounds like a project for 2016.
The only reason I was considering dropping to 12V was so that my charger could get 2 of my batteries charged quickly and if I ran out of power I could repeat the process. Not elegant, but nothing to buy. Now that I found out I would need a new inverter the idea is less interesting
Last month I connected a kill-o-watt to a 5000BTU window AC unit and if I remember correctly peak draw was something like 400 watts with the compressor running and a lot less with just the fan. If I had a battery setup with 5568 watts I could probably run that AC for most of the weekend and still make coffee.
full_mosey wrote:
MWO is Microwave Oven. Sorry.
This forum is so full of abbreviations there is no way to know them all. Someone should write a glossary sticky post.
full_mosey wrote:
I did make a mistake on the adding 1 12V to get 300AH. That would yield 36V in series.
I wasn't sure if that was a mistake or some wacky parallel + series method to get me more AH, but I got the idea.
full_mosey wrote:
X2 on solar. I run two 12V banks and both depend on solar with a genny for catchup bulk charging. It is too expensive to run a genny to get the bank fully charged. Bulk charging by genny can get you to 90% in about 3hrs, but it can take much longer to get that 10% while your genny slurps fuel. Solar is a one-time expense. Details of my system are in my profile.
HTH;
John
Yes, Running the genny to charge our system is too expensive in terms of gas, time, noise and generator hours. Over the last day I've come to realize that we probably have never fully charged it and this explains why it has never worked very well.
I was considering dropping down to a 12V(2x6V) system because of the expense of charging 8 batteries with our setup. It would charge fairly quickly.
