pianotuna
Sep 04, 2013Nomad III
Hi,
TripLite is a high quality MSW inverter.
Forget the induction cook top--they require pure sine wave.
I would buy one dimable LED 120 volt bulb and try it.
115 minutes is the "reserve capacity". There is an approximate formula for conversion to amp-hours at the 20 hour rate. Check the wobbly wide web.
A good guess may be 200 amp-hours per battery. Since the system is 24 volts that gives you 400 amp-hours X 24 v = 9600 watts. Of which you can use 4800 safely.
In your shoes I'd start by fully charging each individual battery, then equalize and finally desulphate.
Since there are 8 you could keep four "in service" while treating the other four one at a time. The catch will be time as desulphating can take over 24 hours per jar.
In any event, get solar.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
