SkiMore
Sep 05, 2013Explorer II
full_mosey wrote:
Yep! You should go ahead and use all your batteries. Then when you run the genny, at least it will have something significant to do and make better use of fuel.
I think the generator+charger+battery setup I have is a loosing inefficient battle.
My charger is only 24V@30A = 720watt
Generator = 7000watt (I'm only using 10% of capacity)
Battery bank is 8 batteries * 200A(approx) x 6V = 9600 watts
I'm not sure how many hours it would take to charge the batteries anywhere near capacity, but I do know that it is way longer than I'm interested in running the generator. And, I don't need 9600 watts (4800 usable) than I need for a weekend.
I think that solar is the answer. Get a 200-300watt system and let it charge the batteries while I'm not there and hopefully not need the generator.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
