SkiMore
Sep 05, 2013Explorer II
MEXICOWANDERER wrote:
Chew on this: At 80% charge when a pair of batteries can digest maybe 20 amps, three pair can digest SIXTY amperes. Double the ampere hours double the SAFE amount of amperes. Works the same for a string of sixty two volt cells for high wattage inverters, (add another bank) or for 2 single 12 volts. When my batteries are almost charged they are accepting over a 100 amps!
I didn't understand this when you wrote it a couple of days ago. I'm trying to chew on it now. Is that the setup you have? Do you run a full home offgrid?
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
