j-d
Nov 26, 2013Explorer II
Don't trifle with a failing Chassis Battery. Neighbor just loaned his Class A (on Ford F-53 with V10) to a friend. Friend got to the storage lot and found the battery very low. Kept trying to crank it. I don't know if he even knew the coach (probably) has start assist from the House Batteries, but the Starter Motor and Starter Solenoid both had to be replaced that day. I suspect that permanent magnet starter took a dim view of low cranking voltage and threw in the towel.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
