Almot's avatar
Almot
Explorer III
Nov 25, 2013
Nearly dead starter battery - what to expect?
I wrote briefly in another topic. 5 years old, left in a warm climate for 8 months with terminals disconnected. Upon return found it completely discharged, Voc=11.86. Multimeter "might" read lower than it is, but 8 months is enough for a complete self-discharge anyway. Water was 1/8" below the plates, added water to the mark.
Charged until current dropped to 0.5A, which is just about right - don't know the capacity in AH, they never tell this on starter batts, but by the size and weight ~40 AH.
Could only raise the charging voltage to 14.4, then it went into absorption stage (setpoint was 14.6, but it didn't want to raise it that high).
Tried to equalize at 15.5V, but it wouldn't raise the voltage over 14.7, so equalization is now "new absorption".
Wintering in Mexico away from civilization - though with solar power - I wonder what can be done and what to expect.
Buy Trik-L-Charge? Not sure that local village store would even know what this is, and it won't let me stray too far from the solar panels and my rig. When not driving, it's losing charge at the rate ~8% A DAY. Can buy a new battery, but if I leave it again for 8 months I might as well buy it next winter. Questions:
1) What can be done to restore it a little - prolonged charging, desulfators, snake oil?
2) It runs the truck, but how dangerous is to drive with such a battery, can it just fail down on me on the road?
3) Will try and find some maintenance option for the next long storage, but what if I leave it again for 8 months - will it degrade so badly that wouldn't accept charge at all?
  • For long storage you can use a solar panel charger sold at Harbor Freight or Northern Tools it will maintain the battery.
    Or take the battery out and put it on a bench with a trickle charger
    Or use the trickle charger with the battery in the vehicle.
    Anytime my batteries get beyond 5 years I expect the possibility they will fail.
  • Desulfate it. This is what I just love about stupid smart chargers. They don't work.
    The battery is on its last legs. Five years in a warm climate makes it = to an octogenarian. If you drive mostly short distances, you may have left with the battery 70% charged.
    If the motor never gets shut off then there is little chance the battery will fail to start the car. Otherwise it is a crap-shoot.
    Being a maintenance charger with you from home. And a gallon of distilled water. Some purified drinking water down here has high TDS.
    I recommend for 28C a maintenance voltage of `13.4
Having RV issues? Connect with others who have been in your shoes.24,364 PostsLatest Activity: Mar 07, 2026
