enblethen
Oct 04, 2017Nomad
Check the back of the refer(outside access0 for 12 volts DC.
Verify fuse has power on the refer side.
Check fuse on the circuit board in the exterior access.
Stove pilot or automatic light has a small brass valve under the stove top. It should be turned to provide fuel for the lighting system. We do not use ours. We leave it off and light the burners as needed.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 09, 2026
