lawrosa
Mar 15, 2020Explorer
Need batterys.
Had 12 volt duracells DC 24. Served me OK. lasted 6 years. They were january 2014 matched pairs.Cell went dead on neg side battery I Run 1100 watt inverter and do the coffee maker thing and toaster...
lawrosa wrote:I am going with how you can run the big things on the 2000w inverter down to 75% SOC on two 6s before the inverter hits the 11v alarm with voltage drop, compared with how you can run the same load at 50% SOC if you have four 6s.
Ummm so let me ask. after such load is applied to 75% then 11 volt alarm goes off, what voltage do the batterys recover at??????
