AISURFFISH's avatar
AISURFFISH
Need direction. ATWOOD heater not staying lit
I turn on furnace at the stat...
The furnace fan starts.. then the igniter clicks.. the propane lights. There is flame and heat then after 2 seconds once the ingnighter stops the flame stops but the fan continues to run.
This will repeat 2 more times total of three.
Then everything turns off.
I then see a red flash on the board
2 flashes then a 3 second delay..
Then repeats..
I can reset the breaker and the entire sequence will repeat..
Where to start?
Remove the coupler and start cleaning..
Then try to replace board?
