88flaminchevy's avatar
Nov 30, 2015
Need help adding a transfer switch
Hello,
I'm putting together a new trailer for my wife's business and I'm a bit stumped adding a transfer switch after the generator. I bought the WFCO 50 AMP TRANSFER SWITCH (WFCO T-57) Our generator is an Onan marquis 5500. The generator has 2 30amp breakers on it and 5 wires coming out. 2 Blacks, 2 Whites and 1 green. Nothing in the trailer runs over 120V, so I don't need to set it up for 240V. I just want 120V 60HZ.
Attached is a picture of the install instructions for the transfer switch. I'm assuming for the terminals marked "generator" 1 black goes to L1, 1 black goes to L2, the whites both go together to Neutral and Green obviously to GND. Then my breaker box after the transfer switch, I'm only using L1 and Neutral on the load terminals. Does this all sound correct? Why is there a jumper installed between Neutral and AUX? Please someone correct me if I'm doing something incorrect.
Thank you!!
Having RV issues? Connect with others who have been in your shoes.24,315 PostsLatest Activity: Sep 09, 2025
