My stabilizing jack and slide outs operate on hydraulic. I retracted the slides and it quit operating. There is a selenoid with heavy gauge wire attached to it near the pump, that clicks on and off w...
The pumps 12V, check the battery and make sure it has full charge. Likely you have the LCI Ground Control 3.0. Here's the manual with trouble shooting: https://support.lci1.com/ground-control-3.0-support-ground-control-3.0-onecontrol-touch-panel
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 13, 2026
