DrewE
Jul 16, 2018Explorer III
doxiemom11 wrote:
We have a 50 amp motorhome and the microwave/convection is built-in. The microwave part is 800 watt . You may want less than the 1000 watt to reduce the power consumption.
The Panasonic Inverter microwaves are great in this regard; when run on a reduced power setting, they actually consume less power continually (at least down to some power level) rather than simply cycling at full power as basically every other microwave does. In other words, using one at 70% will use 70% of the peak power, rather than peak power 70% of the time.
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: May 23, 2026
