Alan_Hepburn
Jul 17, 2018Explorer
Are you replacing an existing microwave, or adding one? If you're replacing one, then the cabinet is already built to handle the weight, and the microwave is most likely a standard under-cabinet unit so you can get pretty much ANY brand that is listed as an under-cabinet model - just be aware of how they are vented.
On the other hand, if you're adding a new one you'll most likely have to reinforce the cabinet to carry the weight, and maybe even reinforce the cabinet's connection to the wall/ceiling. Then you'll have to add a new power outlet and run some romex back to your power panel - most microwaves will be connected to a dedicated 15A circuit breaker - while they CAN be plugged in to an existing outlet if anything else is running off that line you'll be popping the breaker.
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: May 23, 2026
