PDX1953
Jul 17, 2018Explorer
Alan_Hepburn wrote:
Are you replacing an existing microwave, or adding one? If you're replacing one, then the cabinet is already built to handle the weight, and the microwave is most likely a standard under-cabinet unit so you can get pretty much ANY brand that is listed as an under-cabinet model - just be aware of how they are vented.
On the other hand, if you're adding a new one you'll most likely have to reinforce the cabinet to carry the weight, and maybe even reinforce the cabinet's connection to the wall/ceiling. Then you'll have to add a new power outlet and run some romex back to your power panel - most microwaves will be connected to a dedicated 15A circuit breaker - while they CAN be plugged in to an existing outlet if anything else is running off that line you'll be popping the breaker.
I'm adding one to a custom mini toy hauler (12' x 7') and bought brackets that mount to the wall. If I can't find 2 studs in the right place I'll bridge them with a piece if 1" x 3" oak trim I have laying around. The stove will only be used with shore power or via my genset.
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: May 23, 2026
