DrewE
Feb 17, 2020Explorer III
Teacher's Pet wrote:
As Scottiemom has said a "fuse" was the problem. 1998 Intruder Class A on a F53 Ford chassis ... I know it doesn't make sense...changed a blown "cruise control" fuse and all was well never had the problem again. BTW the television interlock was on same fuse circuit.
Apparently the interlock that won't let you shift out of park unless the brake pedal was pressed is on the same circuit which had the blown fuse. Sometimes there's some way of mechanically bypassing this solenoid that's detailed in the vehicle's manual (which would be used, for example, if one needed to put a dead vehicle with a dead battery in neutral in order to haul it around somewhere).
I would not bet money that the poster's old motorhome has such an interlock, but I suppose it might.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 17, 2026
