enblethen
Jan 16, 2020Nomad
Yes with ignition on and engine running, there should be voltage on the coach battery cable.
Check for voltage on each side of the circuit breakers in detail.
The KE wire should have power to switch.
The momentary switch is for temporary tying system together for emergency start.
The dual function is for charging the batteries.
