BFL13
Jan 20, 2020Explorer II
So with the rocker, you can push MOM and now the solenoid closes, then you turn the key to "Start" and instead of the solenoid opening as when powered from the engine battery, it stays closed from being powered by the house battery?
So you should turn off the heater fan etc yourself to reduce the total drain on the house when starting?
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 23, 2026
