BFL13
Jan 21, 2020Explorer II
Somehow I got the notion that when you turn the key to Start, that cuts off the blower motor etc including the power to the solenoid from the engine battery.
With MOM you get house battery power to the solenoid, not any engine battery power if I got that right.
So with MOM when you turn the key to Start it can cut off Engine battery power to the blower and solenoid, but that power is now from the House, so it all stays on is what I assumed.
You are saying that with MOM, the key in Start still cuts the house power to the blower, but leaves the power to the solenoid on so it stays closed.
So even when on engine battery, all normal, turning the key to Start cuts power to the blower as one event and separately somehow on a different line somehow also cuts the power to the solenoid.
MOM is able to distinguish between these two events and only cuts the power to the blower and not to the solenoid?
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 23, 2026
