maillemaker
Jan 21, 2020Explorer
Going from Run to Start cuts off non-essentials and the power to the solenoid normally. So there are switches of some sort responding to the key position. You try to start normally but the engine battery is too low.
You push MOM and try again using the key to Start. Non-essentials are still switched off same as usual, but this time power stays on to the solenoid (or there would be no power to the starter).
Yes. The MOM switch uses the house batteries to energize the charge solenoid.
If the house battery power is just passed through to the engine side via solenoid, the brain that gets the power to run and switch off the non-essentials would not know the difference which battery bank is supplying the power. Seems to be the case.
Yes. That "brain" is the ignition switch.
But now for some reason the brain running the power to the solenoid can tell the difference?
I don't know how it works, but the when the ignition switch is in START, accessories are turned off. This is going to be true in pretty much any car.
Maybe the MOM by-passes the solenoid to parallel the house with the engine batt some other way, and it all acts the same as when on engine battery, but the solenoid being open in Start does not cut off the house battery power, because it by-passes the solenoid when in MOM??
I don't understand what you are saying here.
I think it is really very simple.
MOM is just like taking a pair of jumper cables and hooking up a second battery to your engine battery. That's all it does. The difference is instead of jumper cables it's a solenoid operated from the house battery juice.
DUAL does the same thing, but it uses the RUN switch juice.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 23, 2026
