Shot-N-Az
Jul 08, 2013Explorer
Thanks for all of the wonderful replies! I poked around a little more, and sure enough, there is a white ground wire hidden up in the plastic sleeve that covers or protects these hot and ground wires in the engine compartment. It appears the connectors are beginning to fail because when I opened up the protective sleeve, a connector fell out.
I'm going to reconnect everything and hopefully, that will be the end of this little problem.
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
