D_E_Bishop's avatar
D_E_Bishop
Need help with the In-Tank pump, FOUND SCHEMATIC OL
I have written about the starve out problems I've been having with the 1989 Chevy naturedly aspirated 454 in our rig. I had it to a shop to repair what needed repairing so I would pass smog here in CA. I have been to four shop since it pasted smog but still won't climb hills and asked each shop to check the in-tank pump pressure on the output side of the regulator. None of the shops checked, all said it was an electrical problem.
Today I bought a very good pressure gauge, 20 feet of gas hose and the fittings to install the gauge and hook up to the regulator. Zero pressure. The regulator is not the problem. There is free flow through the regulator, there just isn't any pressure.
I would like to verify that there is power to the pump but don't have my factory schematics, they are in the garage along with 3/4 of our belongings due to a remodel and complete interior paint. Our kids and grandkids moved most of our stuff and it is all mixed up and I'm not sure where anything is.
Does anyone have a full set of wiring schematics for a 1995 Bounder? Or can anyone tell me exactly where and what color the wires are up in the cockpit? I didn't have a full set of attachments for my DMM so I couldn't check voltages accurately at the disconnect by the tank. I'm going back out tomorrow and try again but a schematic would sure help.
We are leaving Monday for a little road trip and I'm not looking forward to the motels.
TIA
Found not only the schematic but a description of the entire oil pressure interlock system and why pressure builds up in the fuel tank.. There is a lot of other things I figured out after reading some stuff on Google and now I know that the pump is working and that the relay interlock is bad.
  • Not familiar with your setup. Relay's do go bad. Check that first.
  • Power goes through the wire that will make a test light glow with the igntion switch turned on. The test light will play possum when the Fuel Pump fuse is pulled. The pump most likely has a relay so underdash work may not be fruitful.
Having RV issues? Connect with others who have been in your shoes.24,333 PostsLatest Activity: Nov 06, 2025
