KD4UPL
Jul 08, 2015Explorer II
Yes, you can use it. I've never yet seen a 240v hot tub circuit that didn't have a neutral. But, verify there's a white wire in there along with the ground and 2 hots.
Are you installing a 30A or a 50A RV outlet? If a 30 amp then you'll connect to ONE hot wire and the neutral. If a 50A you'll use BOTH hot wires and the neutral. In both cases you will, or course, also use the ground. So yes, a 50A RV outlet does infact have 240v despite what some people will lead you to believe.
I would get an electrician to at least check your work. If you get it wrong you could destroy some or all of the electronics in your RV.
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
