Seabeedaddy
Jul 09, 2015Explorer
Yes it Can be Done.. You can use one of the hots as your feed and disconnect the other hot and RE-WIRE IN PANEL and use it as your Neutral and leave the ground as is!! But it doesn't sound like you know a lot so it may be best to Hire a Electrician! Good Luck
Having RV issues? Connect with others who have been in your shoes.24,364 PostsLatest Activity: Mar 07, 2026
