Artum_Snowbird
Mar 11, 2014Explorer
"For this weekend I would sandwich two pieces of plywood together, one on the inside & one on the outside, with a couple of bolts to tighten the pieces together, to cover the opening. "
Good idea Bear... or even pexiglass. A local plastics shop should be able to cut you a couple of pieces. Put some double sided foam tape onto the window frame and around the four bolts and away you go.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
