Bionic_Man's avatar
Bionic_Man
Need Replacement Microwave
My microwave bit the dust. Trailer is a 2002 Gulfstream. Old microwave was a Samsung MR5493G. Dimensions are 20 1/4” high by 14” wide and 14” deep.
The trim plate is 23” wide x 17” high.
Cabinet has a 21 1/4” x 15” opening and is 16” deep.
I can’t find anything with similar dimensions. Have checked Lowe’s and Home Depot. Amazon and eBay. Camping world. And a general google search.
Does anyone else have a possible source?
  • ppine's avatar
    ppine
    Explorer III
    We had the same problem in the house. We just decided not to use a microwave. I never use the one in the trailer either.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    Ok, first the microwave you had was identical in every way to one sold for home use. So shop best buy et-al.
    Second. Depending on the venting in the microwave cabinet you may need to have a HEVAC shop bend some sheet metal and attach it so the hot exhaust gasses go where they need to go.
    You can also build a new "Face plate" or use filler's to fill it in.
    Or .. I just set it aside and do not use it.
  • I have a MR4381G similar dimensions and I’m going to switch to a small .8 cf inverter microwave since I boondock a lot. Only Panasonic and LG have small enough models to fit.
  • I hope my old microwave ( ‘94 ) keeps working. I love that has only 2 dials, I don’t have to put on glasses to read all the buttons on a new one.
  • When mine bit the dust I picked one up at Wal-Mart it was slightly smaller which was good as the vents are on the side not the front. Has already out lasted the original.
  • When the original Sharp microwave in our coach died, I went to Walmart with a tape measure and found a Hamilton Beach oven that was a perfect fit for the ventilated trim plate opening. The only mods required were small shims for the feet and minor reshaping of the trim attaching straps. If needed, I could have easily modified the trim plate for a larger unit within the limits of the cabinet opening. Keep looking, but don't be limited by the trim opening.
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jan 16, 2025
