wa8yxm
Jul 14, 2015Explorer III
1. With 12v fans, how far down in voltage can I run them before I start damaging the motor? (Assume the usual cheap computer case fans you're likely to get in a desktop.)
Quiet a ways. the Brushless DC fans used in computers will stall if you go too low.
2. When voltage goes down, amperage goes down; will low amperage damage the fan?
Wong, as voltage goes down, speed goes down, current increases believe it or not.
3. If I use a "quick and dirty" 12v to 5v USB car charger to run a 5v fan, will the loss of voltage (and amperage) between 12 and 5 as the panel becomes less effective cause any issues?
Well any time you use any device to change voltage there is a loss of effiency.. However you coudl loose half the panel output voltage and it might still work.. Depending on the USB thingy.
4. What's more important to fan speed; volts or amps?
Both... But they both become voltage.. IF the power source can not provide the amps.. the result will show as low voltage.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
