laknox's avatar
laknox
Nomad
Jul 14, 2015
Need some electrical edjumakashun...
I'm trying to cobble together a small exhaust fan, solar powered. I have a bunch of old computer fans, both 5v and 12v, and am having trouble figuring out what I can run and how much panel I need. Main questions are:
1. With 12v fans, how far down in voltage can I run them before I start damaging the motor? (Assume the usual cheap computer case fans you're likely to get in a desktop.)
2. When voltage goes down, amperage goes down; will low amperage damage the fan?
3. If I use a "quick and dirty" 12v to 5v USB car charger to run a 5v fan, will the loss of voltage (and amperage) between 12 and 5 as the panel becomes less effective cause any issues?
4. What's more important to fan speed; volts or amps?
I know there are a lot of DIY "instructions" out there, but they're usually not real detailed, nor do they explain a lot. Any info is appreciate.
Lyle
Having RV issues? Connect with others who have been in your shoes.24,338 PostsLatest Activity: Nov 27, 2025
