time2roll
May 27, 2021Nomad
E05 Red Overload shutdown
Short circuit
Reduce or disconnect the load. Make sure the load does not
exceed the XM 1800’s output rating.
Check connection to the load.
Are you certain the inverter only powers the fridge?
I assume you may need to cycle the inverter power off/on to get the inverter to restart.
What is the battery voltage?
Short circuit
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 28, 2026
