dougrainer
May 27, 2021Nomad
E05 Red Overload shutdown
Short circuit
Reduce or disconnect the load. Make sure the load does not
exceed the XM 1800’s output rating.
Check connection to the load.
The best way to remove the code is to disconnect from Shore Power and disconnect the Coach batteries for 5 minutes and then reconnect the Coach Batteries and plug into shore Power. Hopefully the code goes away. The Xantrex Pro---Can you tell us the Model? Your refer pulls minimal AC current, less than 300 watts, and almost any Xantrex Pro will power the refer OK. Did they install 2-6 volt Golf Cart batteries or 2-12 volt Golf Cart Batteries? Doug
Short circuit
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 28, 2026
