2oldman
May 27, 2021Explorer II
mrad wrote:Hard to say without a monitor. I see reports all the time that it doesn't disconnect as completely has removing a battery cable leaving no other wires attached.
I have a disconnect switch right at the batteries, and another in the storage area. would turning off the disconnect at the batteries work the same a physically disconnecting them?
After years of RVing I found that 4 6v batteries work much better than 2 with an inverter. I'm sure you'll be running other things besides that refer, and you don't want to have to turn it off when you do.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 28, 2026
