StirCrazy
May 27, 2021Moderator
mrad wrote:
Sooooo....Do I need a bigger inverter/converter or more batteries. I should state the only time I will be using battery power would be if I brought the rig to work to leave from there.
Also, why does the Xantrex have an on/off button on the readout gauge? When should it be on, and when should it be off????
I would say both. a 2000watt inverter and two more batteries. an average fridge will use up to 8 amps on start up and a 1000 watt inverter just doesn't cut it.
Steve
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 28, 2026
