dougrainer
May 29, 2021Nomad
wa8yxm wrote:
Which Xantrex?
On the Prosine 2000 the on/off on the inverter is a true on/off OFF is OFF and I mean OFF no power passes through it not 120-120 not 12-120 or 120-12 NOTHING moves and the remote is dead
On the remote it is an Operate/Standby switch (Does not turn it off just disables it) leave it on.. Why. When on shore power automatic switches do the same job and if shore power is lost.... My TV's did not blink
Freedom 2000 is a bit different (no "Big" switch) but effectively the same Leave on
If you would READ the posts you would know which Xantrex. He posted below 24 hours before your post.
My model is the Xantrex Pro XM1000. I just unplugged it from shore power and hit the disconnect switch
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 28, 2026
