happy2rv
Apr 27, 2020Explorer
Don't want to hi-jack the thread, but is it just me or are there fewer valves in a nuclear power plant? :h
Unfortunately the diagram and the manual don't provide any insight into how the manifold or valves are actually plumbed. A couple of things to check. The manual mentions a water heater bypass valve like it is not in the utility bay, probably behind the water heater. Another culprit that congressionally causes issues is the outside shower, or the inside shower for that matter (although I assume the inside shower gets enough use that it would have been discovered). The showers can be shut off at the spray handle but the hot and cold valves be open allowing water to circulate through the fixture.
