3_tons
Apr 27, 2020Explorer III
I recently had a similar problem whereby the toilet pedal got slightly hung up in the midway position which meant that both the water inlet valve and toilet dump valves (both mechanically connected) were simultaneously ‘slightly open’ at the same time, causing the pump to cycle off and on but with NO appreciable change in the residual water level in the toilet bowl - this because of a near state of water in and out equilibrium...Once I tapped the foot pedal, the pump quit cycling... This was a weird anomaly, but something to keep in mind...
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
