DutchmenSport
Jan 22, 2016Explorer
This is the type of receptical box you want to put in the wall. The wall of your camper is thin paneling of some sort. If you have access to the back of the wall (like in your cabinet), then this box will work very good.
Cut your hole in the paneling to fit the box. Insert the box, then turn the wing tips so they catch the inside of the paneling. Then tighten down. Run your wire, attach the plug, put on a face plate and your done.
The are designed to NOT be attached to a stud, but for paneling and dry wall between the studs.
Click here.
Click here.
Having RV issues? Connect with others who have been in your shoes.24,396 PostsLatest Activity: Jun 24, 2026
