CA_Traveler
Jan 23, 2016Explorer III
doughere wrote:Either way would be fine. Since it's for the GCs I'd make sure that the plug is GFCI protected.IBcarguy wrote:
Thanks to those that have offered some POSITIVE input...it's appreciated. I think there are some good suggestions for the outlet itself but should I create a dedicated circuit with it's own breaker or tie into an existing circuit?
It is probably easiest to add a 15Amp breaker if you have space in the box. If no space, you will need to disconnect an existing circuit, use it to feed this outlet, and then connect that circuit to this outlet.
Doug
Having RV issues? Connect with others who have been in your shoes.24,396 PostsLatest Activity: Jun 24, 2026
