Wet_Coast
Jan 23, 2016Explorer
new TT and I want to add a 110v outlet in the bunk bed area for the grandkids to plug in their Ipad chargers, TV, games, electric blanket, etc.
OK, lets back up a bit. First off it's 120v. small point.
Now, if it's just another plug to run something like a wall wart for charging mobile device. Just add another outlet. Draw will be negligible. Rule of thumb is 10 devices (lights or plugs on a circuit). Figure out how many devices are on that circuit now before getting to far into this.
The electric blanket; that's different. That device will draw 10 amps or better and should be on a dedicated circuit. Depending on the service rating (amp rating of the panel/trailer feed), you might want to think about running that circuit all the way to the outside of the trailer and using a second outlet (circuit) on the power distribution point at the RV park. I am assuming this is shore power and not genie powered?
And stranded wire would be recommended if doing a lot of gravel roads. My 1987 5th wheel had solid core lumex and the wires are holding up fine.
And yes, I am an electrician.
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 16, 2026
