IBcarguy
Jan 23, 2016Explorer
Lantley wrote:
As others have mentioned from your questions you don't sound very knowledgeable when it come to electric. However lets back up a minute.
Are you OK with simply adding another circuit via an electric cord that plugs into the CG pedestal?
If not are you capable of running a wire from your desired outlet location to the breaker box of the RV. You can run wire within cabinets or beneath trailer. However it needs to be done in a neat secure concealed manner.
Installing the box and making the connections is not the difficult part.
No, I am NOT going to run another circuit from the CG box. All I am going to do is add another outlet in the bunk bed area. My questions are mostly asking if I should run a dedicated circuit with an additional breaker or if I should run if off of an existing circuit. Granted, I am not an electrical expert but I am mechanically inclined (former auto tech) and I know that this isn't rocket science. With a little research and coaching, this shouldn't be any big deal.
