IBcarguy
Jan 24, 2016Explorer
I finished this job this afternoon and it was no big deal. Installed 2 outlets, one for the upper bunk and one for the lower. I installed a 15A breaker and ran a new circuit. I used the thin boxes with double outlets and double USB ports. Another great tip from here was to glue pieces of wood to the opening I cut to thicken the paneling. The only problem I had was there was a big vent pipe in the wall that made the box a little tight so I had to move the hole over a little but the outlet trim covered it.
I was careful, took my time and it turned out to be a nice addition to the new trailer.
Thanks to all that offered good ideas and encouragement. To those negative people out there that insisted I should hire a pro.....I TOLD YOU I COULD DO THIS!
