maillemaker
Mar 07, 2016Explorer
You can put in whatever works. I'm not sure why you're concerned about such a small power draw.
Mostly I'm concerned about increased pressure in the plumbing.
My drain valves already leak, and are not accessible to replace. At least the two under the bathroom sink are not.
They mostly leak when if they are stuck in between fully open and fully closed, but weep even when closed.
But I'm mostly curious why they would spec out a pump with different operating parameters from the original when it seems like there is a pump out there that matches the original specifications almost exactly.
Original pump:
2088-403-144
http://www.fourwh.com/2088-403-144.pdf
Factory Shutoff: 45 PSI
Max Flow: 2.8 GPM
Max Current: 4.6 amps
Supposed replacement:
4008-101-E65
http://www.campingworld.com/shopping/item/shurflo-revolution-water-pump/49007
Factory Shutoff: 55 PSI
Max Flow: 3.0 GPM
Max Current: 7.5 amps
Best match I found:
https://www.freshwatersystems.com/specifications/2088-554-144.pdf
Max Flow: 3.5 GPM
Max Current: 5.2 amps
Also the physical form factor of the best match I found matches the form factor of the original more closely.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
