maillemaker
Mar 08, 2016Explorer
I already ordered the new pump.
Yes, the valves themselves leak. They seem to do OK if you make sure they are fully closed, but still dribble a small amount.
Steve
I think Chris is saying that if the low point drains stick down on the outside, you could add secondary caps. That won't work if the valves are leaking onto the floor, but will if they leak out the drain and onto the ground.
Steve
Having RV issues? Connect with others who have been in your shoes.24,350 PostsLatest Activity: Jan 18, 2026
