maillemaker
Mar 09, 2016Explorer
Is the low point drains the only thing those pipes that disappear into the floor go to? If so, you could leave the existing valves open and install new inline valves in the accessible tubing above the valves. That would prevent the leaking/weeping when the existing valves are shut, at least.
Nope, they are inline on the cold and hot water lines that run through/under the flooring from the bathroom on one side of the RV to the shower on the other side of the RV.
There is a small hole in the carpet/floor to reveal where these valves are but that's it. The inlet and outlet sides disappear under the carpet/floor.
Steve
Having RV issues? Connect with others who have been in your shoes.24,351 PostsLatest Activity: Jan 19, 2026
