Anonymous
Mar 19, 2014Need your help with portable generators
I just purchased a 21' TT and I'm trying to decide which generator I should get. I don't plan on using the genny to run the AC at this time, so I'm looking to get the smallest and lightest genny that I can get that will charge the batteries, run the microwave, coffee maker, and a hair blow dryer on low setting. No, I'm not planning on running all these devices at the same time. ;)
The trailer came with a 55 amps output converter and the specs say the input is 950 watt. The microwave manual says the energy input is 1,350 watt and the output is 900 watt. The small coffee maker is rated at 650 watt and the hair blow dryer is rated at about 950 watt at the low setting.
I know most of you highly recommend the Honda and Yamaha generators, however, I can't justify the expense since we are only going to need a genny for the few time times that we will be boondocking. I already own a contractor grade genny that I use at home when the power goes out, so whichever genny I buy will be used exclusively when boondocking.
I have been looking at the 2,000 watt Champion genny, and based on what I have seen in this website and other places, they seem to be good little units at an affordable price. If I'm not mistaken, this unit is rated at 2,000 watts for starting, and 1,600 watts running.
I'd like to hear from those of you that own this unit, and/or recommendations for similar gennies that may be suitable for my needs.
I plan on carrying the genny and a small, airtight gas container in the bathroom located in the rear of the TT. I have been told the Champion does not emit gas fumes when not in use.
Thanks in advance for your advice, suggestions, or recommendations.
