RTZ6885's avatar
RTZ6885
New AC Install
My 2022 Kountry Star 3412 is currently in the shop at a Newmar Service center for the front AC replacement to the new Freshjet 5. They are having trouble getting it to work. I know Dometic tech support is involved in this conversion with the service techs but they're all scratching their heads on this one. The old Penguin II has a failed control board and other issues. My extended warranty is covering the repair thankfully but hoping this gets resolved soon.
  • Just got the new Dometic Freshjet 5 15.5k AC/Heat Pump installed that replaced the failed Penguin II in my 22 Kountry Star! I still use the same panel up front, so much quieter, no vibration and it blows cold! Everything works! The work was done at NIRVC in Nashville, and they went way out of their way to get this done! The key to this upgrade for us Newmar Owners with Penguin II and the KIB panel with the HVAC, Tanks, and AGS at this time is that you have to have a working 3312022.000 control board from the old unit or a hard to find new one. My old board had failed but a new one was finally located for this work. The new adapter kit RJ11 to RJ45 for the new Freshjet 5 does nothing for us late model Newmar Owners at this time due to the KIB panel. I know North Trail in Ft Myers Fla for those of you in south Florida is doing the same conversion with the procedure I mentioned. The working old CCC2 board is the key. Hopefully Dometic will come out with a Freshjet 5 CCC2 version that is backwards compatible for us Newmar owners. This service was covered by my extended warranty luckily! It took a while to get this resolved but all is good!
  • You got a quarter million $ RV at a shop that doesn’t know how to hook up an air conditioner?  It’s not like they assemble them from scratch. It’s plug the hole with a new unit and connect the wires.
    If I had to ask on the shops behalf why they can’t figure out something this simple, I would not only be embarrassed for the shop but I’d be finding a new shop.
    • Rzeithammel56's avatar
      Rzeithammel56
      It's a problem industry wide with those updating there Dometic CCC2 Penguin II AC/Heat Pump to the new Dometic Freshjet 5. The new Freshjet is not CCC2. It's more than just getting the RJ 11 to RJ 45 conversion cable. Read up on it my friend.
      • StirCrazy's avatar
        StirCrazy
        Moderator
        seems pretty easy for the most part, new thermostat, control moduals for any old AC's being left in place and a rj11 to rj45 adapter.  Dometic says if there is any issues to call them and they will help fix the issue.  as for the ccc2 to ccc3 the moduals take care of that for the older unit and the new unit and thermostat are already ccc3.  prety simple upgrade especial if you only have one AC or if you are replacing them all.  I kinda agree with Grit, newmar shoudl know enough to get the basics down then call dometic for any issues they are running into.
Having RV issues? Connect with others who have been in your shoes.24,362 PostsLatest Activity: Mar 02, 2026
