Bird_Freak's avatar
Bird_Freak
Explorer II
Aug 28, 2013
New Atwood furnace problem.
Ok guys here it is. I had a problem with furnace not staying lit and would lock out after third try. Board showed 3 flashing lights that said igniter. I pulled and cleaned igniter and wire connections with same results. I determined it must be board. Just for kicks I turned it on before ordering new board and it worked fine. Tried it the next morning and back to the same problem. Tried again that evening and worked fine. Same thing today. It is like me. Don't do mornings! Ideas?
Thanks for any help.
  • enblethen wrote:
    Not necessarily. It could be still going to ground through carbon tracks.
    OK,Thanks for the info. I will order it tomorrow.
  • Not necessarily. It could be still going to ground through carbon tracks.
  • enblethen wrote:
    Moisture on the ignitor. Could have cracked one!
    Would the moisture not burn off after it lit and cycled 3 times?
