Dutch_12078
Jun 22, 2022Explorer III
SFVdave wrote:Dutch_12078 wrote:
RV manufacturers often use the same butyl putty tape to install sinks that they use to install doors, windows, vents, etc.
LLPT Butyl Seal Putty Tape White 1 Inch
Thanks, I have a roll on hand.
That's good then. If you've used the putty before, then you're probably aware that i may squeeze out for a time, calling for retightening until it settles down. That's the same as using plumbers putty. Over the years I've used the two pretty much interchangeably depending on which I had on hand when needed.
