rightlaneonly wrote:
I thank each one of you for your replies. I'm going to work on the system today and try the solutions suggested from cleaning the drums and shoes ( I hate pulling the wheels again) to driving it around to seat the shoes. The controller is a Drawtite Activator and is a time delayed one. I did use ten gauge wire. The trailer is an Aliner single axle pop up and is relatively light. About 1200 pounds loaded. I'll post what I find at the end of the day. Again, thanks for all the suggestions, they are greatly appreciated.
Highly recommend removing that Time Delayed Brake Controller, throwing in the trash and replacing with Motion Sensor / Proportional Brake Controller - like Prodigy P2 or P3 brand. If wondering, Time Delay delivers current flow in phases "based on longer time the brake pedal is pressed down". Very, very bad and these brake controllers will NOT initially grab - unless the brake pedal is pressed for some time. And, they don't grad in panic stops either. Thus, putting more stress on your Tow Vehicle brakes.
If wondering, I once installed a "timed" technology brake controller. Within 15 days, I removed and replaced with motion / proportional technology model. Knowing 1st hand experience with each, I will never go back to a timed technology BC again.
Seriously… Pull your your current "timed" BC, put in trash and replace with motion / proportional technology brake controller. Its well worth it!!!
