j-d
Apr 14, 2013Explorer II
Cool But Not Cold tells me something's out of order in the A/C system. Either the system's not making Cold (technically not removing Heat...) -OR- something like a blend door isn't working properly. In most modern automotive setups, the A/C is producing all the Cold it can and the Heater is producing all the Heat it can. The Blend Door gets adjusted to balance the Cold and the Heat to give you the temperature you want.
I can easily see where a Class A windshield is a huge heat source. Many Class A's have supplemental fans up in the front corners to circulate the air in an attempt to help keep the driver and passenger comfortable.
Still, Cool But Not Cold on a 2013 coach tells me you should have it checked and corrected under warranty.
And... Jealous! I like those Winnie Vistas!
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 15, 2026
