beemerphile1
Apr 15, 2013Explorer
Too large of a space for the dash air to cool. Any and all air conditioners should put out air around 20 degrees cooler then the air going into the unit. Home or auto is the same. Compare the temperature at the intake and exhaust, if 20 degree difference, it is working correctly.
Be sure to set it for max cool or recirculate. Normal cool brings in hot outside air. Max or recirculate takes air from the inside of the vehicle and will cool better because it has cooler intake air.
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 15, 2026
